Человек чувствует свой долг лишь в том случае, если он свободен. /А. Бергсон/
Открыта комета Новичонка-Невского
Добавлено: Пн Сен 24, 2012 10:37    Заголовок сообщения: Ответить с цитатой
Нет.
MarsianskiAlien
Благодарности: 12
Добавлено: Пн Сен 24, 2012 14:03    Заголовок сообщения: Ответить с цитатой
Очень здорово! Молодцы!! Ждем подтверждения.
Виталий
Добавлено: Вт Сен 25, 2012 00:00    Заголовок сообщения: Ответить с цитатой
Код:
Central Bureau for Astronomical Telegrams
INTERNATIONAL ASTRONOMICAL UNION
CBAT Director:  Daniel W. E. Green; Hoffman Lab 209; Harvard University;
 20 Oxford St.; Cambridge, MA  02138; U.S.A.
e-mail:  [hidden] (alternate [hidden])
URL http://www.cbat.eps.harvard.edu/index.html
Prepared using the Tamkin Foundation Computer Network
COMET C/2012 S1 (ISON)
     Vitali Nevski (Vitebsk, Belarus) and Artyom Novichonok (Kondopoga, Russia)
report their discovery of a diffuse comet with an 8" coma on four 100-s CCD
exposures obtained on Sept. 21.06 UT with a 0.4-m f/3 Santel reflector of
the International Scientific Optical Network (ISON) near Kislovodsk, Russia
(discovery observations tabulated below); Nevski and Novichonok first reported
the object to the Minor Planet Center with no mention of cometary appearance,
and it was posted on the MPC's NEOCP webpage as an apparently asteroidal
object (their report to the Central Bureau of cometary appearance arrived
nearly a day after NEOCP posting).  Follow-up observations obtained with
a 1.5-m f/8 reflector at the Majdanak observatory in Uzbekistan by O. Burhonov
(measured by Novichonok and Nevski) on Sept. 21.99 show an obvious elongation
in p.a. 305 deg with a coma of size 9" x 11" and total mag about 17.1.  After
the object was posted on the MPC's NEOCP webpage, other CCD astrometrists
commented on the object's cometary appearance (including one or two such
reports received before Nevski's e-mail to the Central Bureau noting cometary
appearance).  W. H. Ryan (Magdalena Ridge Observatory, 2.4-m f/8.9 reflector)
noted an elongated nuclear condensation and a faint tail in p.a. about 280 deg
on R-band images taken on Sept. 21.4; follow-up images taken by W. H. Ryan and
E. V. Ryan on Sept. 22.4 and 23.4 show an elongated nuclear condensation and a
distinct tail in p.a. about 280 deg.  H. Sato (Tokyo, Japan; remotely using a
0.51-m f/6.8 astrograph at the RAS Observatory near Mayhill, NM, U.S.A., on
Sept. 22.5) found a disk-like object 10" in diameter.  E. Guido, G. Sostero,
and N. Howes stacked twenty-four 120-s unfiltered exposures obtained remotely
on Sept. 22.5 with a 0.25-m f/3.4 reflector at the RAS Observatory near
Mayhill to find a slightly diffuse object that was slightly larger than nearby
field stars of similar brightness.
     2012 UT             R.A. (2000) Decl.       Mag.   Observer
     Sept.21.05253    8 12 43.09   +27 50 22.1   18.8   Nevski
          21.05974    8 12 43.23   +27 50 21.7   19.0     "
          21.06577    8 12 43.40   +27 50 21.3   18.9     "
          21.07059    8 12 43.46   +27 50 21.6   19.1     "
The available astrometry (including prediscovery observations identified by
G. V. Williams in MPC data from the Mount Lemmon Survey on 2011 Dec. 28 and
from the 1.8-m f/4 Pan-STARRS reflector on 2012 Jan. 28), the following
nearly parabolic (e = 0.999999964) orbital elements by Williams, and an
ephemeris appear on MPEC 2012-S63.
                    Epoch = 2013 Dec. 14.0 TT
     T = 2013 Nov. 28.8704 TT         Peri. = 345.5614
     e = 1.000000                     Node  = 295.6595  2000.0
     q = 0.012453 AU                  Incl. =  62.3643
NOTE: These 'Central Bureau Electronic Telegrams' are sometimes
      superseded by text appearing later in the printed IAU Circulars.
                         (C) Copyright 2012 CBAT
2012 September 24                (CBET 3238)              Daniel W. E. Green
Добавлено: Вт Сен 25, 2012 00:06    Заголовок сообщения: Ответить с цитатой
Да. Супер! Мои поздравления. clap
Судя по всему, в ноябре 2013 года это будет ОЧЕНЬ яркая комета.
Ждем с нетерпением... Smile
Добавлено: Вт Сен 25, 2012 08:01    Заголовок сообщения: Ответить с цитатой
Ура! Отличная работа! Поздравляю!
Ждём хвостатую! Smile
Добавлено: Вт Сен 25, 2012 09:32    Заголовок сообщения: Ответить с цитатой
Виталий, ты не зря "ждал" свою комету так долго Wink Яркая, северная, с хорошим прогнозом видимости, с маленьким q - все как по заказу, еще бы хвост на полнеба. Будем надеятся, что прогнозы не изменятся и комета приобретет все ожидаемое величие и мощь в конце следующего года.
P.S. Кто может написать грамотную новость для тут, чтобы не было полного копирования с российских новостных лент?
Добавлено: Вт Сен 25, 2012 09:49    Заголовок сообщения: Ответить с цитатой
Ну ўсё, віншую! З заміраннем сэрца чакаў канчатковых рэзультатаў. Проста малайцы!
Toliman
Благодарности: 103
Добавлено: Вт Сен 25, 2012 09:57    Заголовок сообщения: Ответить с цитатой
Супер! Погода только в ноябре-январе неважная. Но успех колоссальный, вот и подтверждение, что астрономическая карма у Виталия после открытия астероида повысилась!
ivan7710
Добавлено: Вт Сен 25, 2012 13:37    Заголовок сообщения: Ответить с цитатой
Зашел на spaceweather и увидел новость, Виталий, низкий поклон вам!
Иван
www.astronomy.domachevo.com
www.aurora.belastro.net
Yahor
Благодарности: 20
Добавлено: Вт Сен 25, 2012 14:33    Заголовок сообщения: Ответить с цитатой
http://it.~вывсёсамипонимаете~/312479 - ужо на ТУТ.by
SkyWatcher 200P/1000 EQ5
SkyWatcher 13065EQ2 + EQ3-2
Добавлено: Вт Сен 25, 2012 15:22    Заголовок сообщения: Ответить с цитатой
Добавлено: Вт Сен 25, 2012 17:41    Заголовок сообщения: Ответить с цитатой
Виталий, ну ты прямо АСТРОГИГАНТ
ak
Добавлено: Вт Сен 25, 2012 18:20    Заголовок сообщения: Ответить с цитатой
Видел сегодня новость на тут.бае - поздравляю!!!
Добавлено: Вт Сен 25, 2012 20:08    Заголовок сообщения: Ответить с цитатой
[url]"Астроном-любитель из Беларуси открыл самую яркую комету за 10 лет"[/url]
Новой комете был присвоен индекс C/2012 S1 (ISON).
Т.е. комета будет называться C/2012 S1 (ISON)? Sad
Как оказалось, ранее эта комета уже наблюдалась: 28 декабря 2011 года и 28 января 2012 года ее видели обсерватории Маунт-Леммон и Pan-STARRS.
А это как может повлиять на название и приоритет с учётом новых правил MPC?
Добавлено: Вт Сен 25, 2012 20:53    Заголовок сообщения: Ответить с цитатой
[quote="astroivan"]
Selestia писал(а):
P.S. И почему thecmaun закрыли, такое поле для деятельности было...
Вообще-то там закрыт бесплатный доступ... А платный открыт.
Виталий
Добавлено: Вт Сен 25, 2012 22:08    Заголовок сообщения: Ответить с цитатой
Сделал пока небольшую заметку под редакцией Артема про открытие кометы на сайте http://www.nevski.belastro.net/ послезавтра спускаюсь с горы, потом сделаем более подробно.
Виталий
Добавлено: Вт Сен 25, 2012 22:18    Заголовок сообщения: Ответить с цитатой
Вопрос с названием еще уточняется, но скорее всего так, поскольку ситуация при открытии была такая, что по правилам следует называть комету в честь обсерватории (что впрочем правильно - это мое мнение)
Исторические наблюдения кометы были найдены только после нашего сообщения об открытии. Здесь ничего не поменяется, т.к. как раз по правилам для NEO и комет - кто первый сообщил от том что это необычный объект, тот и открыватель
Добавлено: Ср Сен 26, 2012 00:22    Заголовок сообщения: Ответить с цитатой
Много интересного появилось в теме "C/2012 S1 (ISON) - БОЛЬШАЯ КОМЕТА ИЗ РОССИИ"
Кратко: если комета переживёт путь к Солнцу и пролёт перигея, то она может стать одной из самых ярких. Высказывается гипотеза (на основании близости значений долгот восходящих узлов и перигелиев) о родственности с "Великой кометой" 1680 г. (1680 V1).
В сети поднялся большой переполох по-поводу этой кометы -- сравнимый с кометой Еленина.
Благодарности: 1500
Добавлено: Ср Сен 26, 2012 00:53    Заголовок сообщения: Ответить с цитатой
Виталий, поздравляю тебя и Артема с открытием. Этот результат есть закономерный итог долгой и целенаправленной работы. То, что открытая вами комета ожидается столь яркой, большая удача. Желаю такой удачи и в будущем.
Добавлено: Ср Сен 26, 2012 08:48    Заголовок сообщения: Ответить с цитатой
Ну что, в ноябре 2013 года ждём байки про конец света и комету-убийцу? Very Happy
Страница 2 из 5
