Цель оправдывает средства. /Н. Макиавелли/
Рекомендации по оформлению кометных наблюдений!
observatoryMazzarot-1 A98
Благодарности: 144
Добавлено: Вс Апр 13, 2008 07:03    Заголовок сообщения: Рекомендации по оформлению кометных наблюдений! Ответить с цитатой
ICQ: Keys to Codes used in Tabulated Observation Format
The International Comet Quarterly OBSERVATION KEYS
TABULATION OF COMET OBSERVATIONS
MAGNITUDE METHOD KEY
Вы наблюдаете на разных инструментах с различными ПЗС камерами... и не знаете, как описать условия наблюдений, тогда вы однозначно попали туда, куда нужно.
Following are key letters for the methods used in making total visual
magnitude estimates (these appear in column MM in TABULATION OF COMET
OBSERVATIONS):
a = orange filter used on SOHO spacecraft with C2 and C3 coronagraphs,
spanning wavelength range 540-640 nm (see Biesecker and Green
2002, ICQ *24*, 95)
B = VBM (Van Biesbroeck-Bobrovnikoff-Meisel) or simple Out-Out method
[formerly noted in the ICQ as the Bobrovnikoff method]
b = VBM method using RCA #4549 image intensifier (see method 'e' below)
C = unfiltered total CCD magnitude (fairly well approximates the Johnson V
band)
c = unfiltered nuclear CCD magnitude (fairly well approximates the Johnson V
band)
D = Cousins B filter
E = Extrafocal-Extinction (or Beyer) method (cf. M. Beyer 1968, Astron.
Nachr. 291, 257)
e = Extrafocal-Extinction (or Beyer) method using RCA #4549 image
intensifier (cf. D. A. Sutherland 1974, J.A.L.P.O. 24}, 218)
F = total magnitude obtained using Meade CCD interference filter CM-500
Visible (infrared blocking filter), supplied with their Pictor 416
CCD camera [ICQ 123]
f = "nuclear" magnitude obtained using Meade CCD interference filter CM-500
G = CCD magnitude with a Corion NR-400 "minus-infrared" filter; William Liller,
who used this combination, says that it "gave a very nice broadband-V
passband" (see Liller 2001, ICQ *23*, 93)
g = CCD magnitude with Gunn g filter (+ RCA CCD w/ observer LAR)
H = Cousins I filter with CCD
I = In-focus
i = visual observation using an image intensifier (observer MER used RTC XX 1390
image intensifier, which has unfiltered sensitivity from 300-950 nm)
J = Kron-Cousins V filter employed (peak transmission at 550 nm) [initiated
by observer ROQ]
j = Kron-Cousins V filter employed (m2 estimate)
K = clear filter used on SOHO spacecraft with C3 coronagraph,
spanning wavelength range 400-850 nm (see Biesecker et al. 2002,
Icarus 157, 323) [use beginning in July 2001 (see ICQ 123);
note that the old "Keen method" deploying "K" as MM was changed to
a special-notes code]
k = CCD magnitude with Cousins R filter
L = photoelectric B
l = CCD magnitude with a Wratten 25 (red) filter, introduced in 1996 by
William Liller "to reduce the atmospheric extinction"; he used the letter
"R" to refer to them (Liller 1997, Planet. Space Sci. 45, 1507)
M = Modified-Out method discussed by C. S. Morris (ICQ 2, 69)
N = called magnitude of nucleus or condensation, but usually some ambiguity
as to whether or not the magnitude refers more to a total magnitude
instead (used mostly with pre-1970 observations extracted from the
literature)
O = Out-of-focus method (specific type not mentioned) [intended for historical
observations only]
o = visual extrafocal comparison using RCA #4549 image intensifier (see method
'e', above)
P = photographic [intended for historical observations only]
p = photographic with Kodak 2415 film
Q = "out-out"; supposed to be same as VBM method, but it's not always clear
what observer intended [intended for historical observations only]
q = R-band magnitude for nuclear condensation
R = photoelectric R
r = CCD magnitude with Gunn r filter
S = VSS (Vsekhsvyatskii-Steavenson-Sidgwick) or In-Out method [formerly
called the Sidgwick method in the ICQ]
s = VSS method using image intensifier (see method 'e', above, for
observer Sutherland, who used an RCA #4549 intensifier; for observer MER,
see method 'i', above)
T = Magnitude estimated from a TV monitor
t = total visual magnitude (no other information provided; historical obs. only)
U = photoelectric U
u = CCD-derived V nuclear magnitudes (m2)
V = photoelectric V
v = photoelectric with filters to match visual
W = photoelectric (no band given)
w = 1P21 photometer + Kodak W64 filter [R. B. Minton writes (1974) that "this
surface-filter combination closely matches the spectral response of the
dark-adapted eye"].
X = ortochromatic film + yellow filter, which is a system very close to the
V band [according to observer MIL02]
Y = CCD magnitude with Wratten No. 15 (yellow) filter, "which gives an
effective response at about 680 nm (and blue cutoff at 520 nm)" [initiated
by observer ROQ]
Other notes: Photographic magnitudes are now indicated under MM by the letter
"P", and photoelectric magnitudes are indicated there by the band letter ("L"
for B, "U" for U, and "V" for V; new letters will be assigned as necessary).
Photoelectric magnitudes with stated errors of > +/- 0.3 or greater get a
colon (:) listed after the magnitude, as of 1982 data; such data stated as
+/- 0.3 gets a '+' instead of a colon.
The letter "W" under MM stands for photoelectric magnitudes in which no
specific band was mentioned (visual band assumed); this will no longer be
acceptable for future observations, but is retained for observations which
already exist in the ICQ master file.
SPECIAL NOTES KEY
NOTE: A left bracket, [, before a magnitude indicates the comet was
not seen. (If the comet was seen, and an observer simply says that it was
fainter than a given magnitude, a '>' sign is used, instead.)
Published after the date in the ICQ (and listed in computer and on
magnetic tape files between the reference and the observer code) are symbols
and letters to indicate special observing conditions or factors
[NOTE: some of these symbols have not yet appeared (and some will never
appear) in the printed ICQ]:
* = an observation completely replacing one previously published in the ICQ
& = comet observed at altitude 20 deg or less with no atmospheric extinction
correction applied
! = observation corrected for atmospheric extinction in a proper manner by
the observer; prior to September 1992, this was the standard symbol for
noting extinction correction, but following publication of the extinction
paper (July 1992 ICQ), this symbol is only to be used to denote corrections
made using procedures different from that outlined in ICQ 14, 55-59,
and then only for situations where the observed comet is at altitude > 10.
$ = comet observed at altitude 10 degrees or lower, observations corrected by
the observer using procedure in ICQ 14, 55-59 (July 1992).
# = minor data change made in archive only (change published in textual form
in ICQ, or not published at all in ICQ) [USED ONLY INTERNALLY]
+ = supplementary descriptive information also published in ICQ
% = comparison star(s) were reduced to visual magnitudes via their B-V colors
using one of the formulae in the ICQ Guide to Observing Comets, first
ed., p. 65 (Howarth and Bailey 1980, or Stanton 1981)
A = Pogson's "step method" or "Argelander method" stated; no other info
provided [for historical observations only]
a = [formerly 'A'] atmospheric extinction correction applied by observer using
Table Ia of Green (1992, ICQ 14, 55-59).
B = a V magnitude based on a conversion from a B photoelectric magnitude
(with same qualifications as for C, above)
b = same as B, except that B-V was not measured, but assumed (usually B-V
is about +0.7)
C = a V magnitude based on a conversion from an R photoelectric magnitude
(the observer must state a proper conversion formula, V-R); if an R
magnitude is given with errors > +/- 0.2 mag, then V gets a colon (:)
after the magnitude.
c = same as C, except that V-R was not measured, but assumed (usually V-R
is about +0.52)
d = local extinction coefficients derived for local atmospheric conditions,
and used in application of atmospheric-extinction correction; the value
A' of Green (1992, ICQ 14, 55-59) is thus re-computed, but the remaining
procedures of that paper are followed
f = single 50-mm binocular objective lens was used close to the eye for
defocussing images
G = Naked eye estimate, with glasses used to defocus comparison stars
(for bright comets only)
i = ambiguity concerning which instrument was used to make coma diameter,
DC, and tail information; the specified instrument was that used for
the magnitude estimate
I = use of infrared-block filter with CCD; supposedly gives response
similar to that of an unfiltered CCD
K = "Modified" VSS method, using binoculars with the comet in-focus in
one eyepiece and with the comparison stars out-of-focus in the other eye-
piece (cf. R. A. Keen 1985, ICQ 7, 48) [originally used as a MM code]
l = limiting stellar magnitude for a CCD observation in which the comet
was not detected
r = binoculars were reversed, such that one looked through the (larger)
objective lens acting as the eyepiece, and the eyepiece acted as the
objective aperture [for the magnitude estimates of bright comets]
s = [formerly 'S'] atmospheric extinction correction applied by observer using
Table Ic of Green (1992, ICQ 14, 55-59).
S = CCD photometry with an R60 filter (expected to be similar to, but not the
same as, that of a standard R filter)
T = a V magnitude based on a conversion from a Thuan-Gunn g, r, or i photo-
electric magnitude (with same qualifications as for C, above); cf.
Jewitt and Danielson 1984, Icarus 60, 435.
t = exposure on Kodak T-Max (b&w) film using an image intensifier (for observer
MER, see method 'i', above)
w = [formerly 'W'] atmospheric extinction correction applied by observer using
Table Ib of Green (1992, ICQ 14, 55-59).
x = denotes that a secondary source was consulted for primary-source magnitudes;
an example is extracting Tycho-catalogue magnitudes from the amateur
software "Guide 6.0". THE SECONDARY SOURCE SHOULD ALWAYS BE SPECIFICALLY
CITED, and will appear in the descriptive information in the ICQ to
supplement the tabulated data.
INSTRUMENT KEY
A = camera lens
B = binoculars
C = Cassegrain reflector
D = Schmidt reflector
E = naked eye
F = twin catadioptric Newtonian binocular
G = coronagraph (introduced for the solar-orbiting SOHO LASCO C3 coronagraph,
which has an external occulter that "shadows the small 9.6-mm entrance
aperture from direct sunlight" -- SOHO website); it is essentially
a refracting instrument [ICQ 119]
H = hyperboloid astro-camera
I = Multiple-Mirror Telescope, F. L. Whipple Observatory (when the f-ratio
was 9, at the Cassegrain focus)
J = Jones-Bird telescope*
K = Klevtsov-Cassegrain (essentially a Maksutov-type instrument but
having a sub-aperture corrector after the secondary mirror, instead of
the full aperture corrector in front of the primary)
L = Newtonian reflector
M = Maksutov reflector
N = 1x monocular made by taking two identical lenses and using one
as an objective and one as an eyepiece
O = opera glass
P = prime focus of a reflector
q = "small telescopes" with aperture in range 4-10 inches (see note under
instrument "r", below) [FOR HISTORICAL DATA ONLY]
Q = "for observations with the largest telescopes" (see note under
r = "small telescopes and finders" with aperture not exceeding 4 inches
(after Bobrovnikoff 1941, Contrib. Perkins Obs. No. 15, p. 5)
R = refractor
S = Schmidt-Newtonian telescope
T = Schmidt-Cassegrain reflector
U = coude focus of a reflector
V = Volosov-Newtonian reflecting telescope (has two lenses -- double-convex
and planoconcave) with a Newtonian spherical mirror; designed by
Pechatnikova and Volosov in Leningrad in 1943 (information
provided by V. L. Korneev in 2000)
W = Wright-Schmidt reflector
Y = Ritchey-Chretien telescope
* According to Henk Feijth, several members of the Dutch Comet Section
use a 10-inch-aperture (25.4-cm) Jones-Bird telescope, which is a modi-
fied Newtonian with a spherical f/4 primary mirror: "Just before the
light strikes the flat after being reflected, it passes through a
Barlow-like achromatic lens that corrects the spherical aberration of
the primary mirror. The system is f/6 and also corrected for coma."
CCD DATA KEYS
[given in brackets is the ICQ reference where the key was announced]
CCD cameras:
Key CCD Camera
Ap4 APOGEE AP47p [ICQ 124]
Ap7 Apogee Ap-7 or Ap-7p [introduced to Keys in ICQ 124]
BT1 BITRAN BT-11 [ICQ 124]
Dil DillCam (used on 2.0-m Faulkes Telescope-North) [ICQ 136]
H24 Hi-Sis 24 [ICQ 121]
MCV Mutoh CV-16II or CV-16 [ICQ 123]
MX9 Starlight MX-916 [ICQ 121]
PIC Pictor 416 [ICQ 123]
PIX Pictor 216 XT [ICQ 128]
PSI Photometrics Star-I [ICQ 124]
S1C a Russian CCD camera (chip unknown; via BOR04, BAR06) [ICQ 132]
SC2 SOHO LASCO C2-coronagraph camera [ICQ 123]
SC3 SOHO LASCO C3-coronagraph camera [ICQ 123]
SE7 SBIG ST-7E [ICQ 124]
SE8 SBIG ST-8E [ICQ 124]
ST1 SBIG ST-1001E [ICQ 124]
ST2 SBIG ST-2000XM [ICQ 124]
ST6 SBIG ST-6V [ICQ 121]
ST7 SBIG ST-7 [ICQ 121]
ST8 SBIG ST-8 [ICQ 121]
ST9 SBIG ST-9E [ICQ 121]
STE StarLight Express SXL8
STL SBIG STL-11000M
CCD camera chips:
Key CCD Camera Chip
EEV 2048x2048 EEV 42-40 [ICQ 136]
F48 Fairchild CCD486 4000x4000 CCD
K10 KAF-1001E (Kodak) [ICQ 124]
K16 KAF-1600 [ICQ 123]
K26 KAF-0261E [introduced to Keys in ICQ 121]
K40 KAF-0400 [ICQ 121]
K41 KAF-0401E [ICQ 123]
K42 KAF-0402ME (Kodak) [ICQ 128]
K4E KAF-0400E [ICQ 123]
K6E KAF-1602E (Kodak) [ICQ 124]
KA1 KAI-11000M (Kodak)
KAI KAI-2000M (Kodak) [ICQ 124]
KA0 KAF-0401 (Kodak) [ICQ 124]
M47 Marconi 47-10 [ICQ 124]
PF1 Philips FT12
SIA SIA502AB (SITe); formerly called TK512 (Tektronics) [ICQ 124]
T24 TC-241 CCD chip (UV enhanced - CCD camera type SBIG ST-6V) [ICQ 123]
T25 TC255 [ICQ 120]
TH7 TH7883CDA (Thomson) [ICQ 124]
TK1 thinned TK1024, Tektronik 1K 1024x1024 [ICQ 121]
Computer software used for photometric reduction of CCD images:
Key Software name
A32 Astrometrica 3.25 [introduced to Keys in ICQ 123]
A41 Astrometrica 4.1 [ICQ 124]
AA3 ASTROART for Photometry, version 3.0
AfP ASTROART for Photometry [ICQ 123]
AFo Astrometrica used with Focas software (see information on WWW at
http://astrosurf.com/cometas-obs/_Articulos/Focas_i/Focas_i.htm)
FPr FitsPro [ICQ 120]
GAI GAIA software ver. 2.5-3 (C) 1997-2000 Central Laboratory of the
Research Councils (U.K.), authors: Peter W. Draper and Norman Gray
e-mail: [hidden] [ICQ 123]
IPL IPLab [ICQ 124]
IRA IRAF [ICQ 136]
MIm MaxIm DL/CCD [ICQ 124]
OPS CCDOPS (SBIG) [ICQ 121]
SI3 StellaImage 3 [ICQ 124]
SI4 StellaImage 4 [ICQ 126]
SI5 StellaImage 5 [ICQ 134]
NOTE: We are advised that software such as "Guide 6.0", "Guide 7.0"
[ICQ 121], "Guide 8.0", and "The Sky (ver. 5)" [ICQ 121] do not have
any means to measure magnitudes (they have only lists of comparison-star
magnitudes), so key codes "G70" and "Sky" are withdrawn.
MAGNITUDE-REFERENCE KEY
See the table
at this website.
Astronomical Headlines
ICQ
Verba volant, scripta manent.
Виталий
Добавлено: Пн Апр 20, 2009 19:33    Заголовок сообщения: Ответить с цитатой
Сейчас, когда стал платить в инете за трафик а не за время, появилась возможность обрабатывать наблюдения не отключаясь от сети. Соответсвенно можно подгружать в процессе обработки данные из каталогов. Решил воспользоваться для фотометрии каталогом USNO-B1.0, который гораздо точнее чем А2.0, но как оказалось В1.0 нет в списке рекомендуемых источников звезд сравнения ICQ http://www.cfa.harvard.edu/icq/ICQRec.html
Сергей, может ты в курсе? Или спросишь у Грина как координатор, а то мне как-то неудобно с такими вопросами к нему обращаться.
Благодарности: 144
Добавлено: Вт Апр 21, 2009 13:42    Заголовок сообщения: Ответить с цитатой
Хорошо, Виталя, спрошу. Я на связи. Как только уточню, сразу выложу информацию....
Виталий
Добавлено: Сб Май 23, 2009 22:19    Заголовок сообщения: Ответить с цитатой
Между тем прошел месяц... Smile
Добавлено: Вс Май 24, 2009 14:59    Заголовок сообщения: Ответить с цитатой
Виталий писал(а):
... Решил воспользоваться для фотометрии каталогом USNO-B1.0, который гораздо точнее чем А2.0, но как оказалось В1.0 нет в списке рекомендуемых источников звезд сравнения ICQ
Виталий, а почему Вы упоминаете A2.0? Ведь USNO A2.0 и A1.0 вообще не рекомендуются ICQ.
Благодарности: 144
Добавлено: Пн Май 25, 2009 13:46    Заголовок сообщения: Ответить с цитатой
Привет всем! Я написал письмо с Виталиным вопросом, но почему-то ответа нет!
Писать еще раз? Так вроде бы согласно этикета ответ бы получить.....
Подождёмс.... Как скажите... Но долбать в закрытую дверь..... дело трудное...
Благодарности: 144
Добавлено: Пн Май 25, 2009 13:48    Заголовок сообщения: Ответить с цитатой
Да и не совсем ты прав Andrey Prokopovich по-поводу A2.0... Другое дело , что он рекомендован, но как крайнее средство, но не запрешен для использования....
Добавлено: Пн Май 25, 2009 14:07    Заголовок сообщения: Ответить с цитатой
Ну даже и не знаю, тут (http://www.cfa.harvard.edu/icq/ICQRec.html) явно написано "Sources that should never be used". Т.е. не должны никогда использоваться. И там в списке USNO А1 и А2.
Виталий
Добавлено: Пн Май 25, 2009 21:40    Заголовок сообщения: Ответить с цитатой
А куда денешься, друго ничего нет. В принципе в А2.0 блеск звезд в основном достаточно корректо указан, просто возможны ошибки, но таких случаев мало и выход из этого - использовать несколько звезд сравнения, тогда сразу видно, если какая звезда сильно отклоняется от своего каталожного значения блеска. Впрочем, в В1.0 такой проблемы нет, по крайней мере пока не встречал.
Благодарности: 144
Добавлено: Вс Фев 21, 2010 12:51    Заголовок сообщения: Можно познакомится с новым руководством ..... Ответить с цитатой
Можно познакомится с новым руководством по наблюдению за кометами ..... Это руководство было написано Д. Грином и Ч. Моррисом.
В свое время оно было любезно предоставлено мне известным наблюдателем комет, моим другом, В.Л. Корнеевым (код в ICQ KOR01). Здесь вы найдете ответы на все свои вопросы.... Руководство еще все не загружено... и будет выкладываться на страницах сайта по адресу:
[url] www.taurusskystars.narod.ru [/url]
На главной странице вы найдете рубрику с последними обновлениями.... Оттуда ссылка вас приведет к "Руководству..." Удачных наблюдений....
