observatoryMazzarot-1 A98
Сообщения: 1229 Благодарности: 144
Добавлено: Вс Апр 13, 2008 06:29 Заголовок сообщения: Обозначение звездных стандартов! Для кометчиков! |
Даю ICQ файл - рекомендацию. Внимательно следите за тем, какие звезды указаны в стандарте! Если будете оценивать кометы по какому-то из ниже указанных стандартов, то внимательно смотрите, какой предел по звездной величине заложен!
К примеру:
CD Open star cluster NGC 225 (R.A. = 0h43m.8, Decl. = +61 47', equinox
2000.0) photometry; star chart with magnitudes given (9.2 < V < 16.0)
Думаю, пояснений не требуется? Знаки больше меньше все знают ))!
MAGNITUDE-REFERENCE KEY
NOTE: For visual magnitude estimation of comets, NEVER USE SOURCES for
which the available star magnitudes are only brighter than the comet!
For example, the SAO Star Catalog is very poor for magnitudes fainter
than 9.0, and should NEVER be used on comets fainter than mag 9.5. The
Tycho catalogue should not be used for comets fainter than mag 10.5.
(Even CCD photometrists should be wary of using bright stars for very
faint comets; it is always best to use comparison stars within a few
magnitudes of the comet when doing CCD photometry.)
NOTE: It is highly recommended that users of variable-star charts also
specify (in descriptive notes to accompany the tabulated data) the
specific chart(s) used for each observation; this information will be
published in the ICQ. Also, observers are urged to not be careless
about the use of secondary references for comparison-star magnitudes:
specifically, if using a secondary source (such as amateur software
containing compilations of professional star-catalogue data, or even
professional catalogues such as the SAOC containing magnitudes from
other catalogues), one should note both the primary and secondary
sources CLEARLY.
*** Recommended Sources:
ICQ
Key Source [+ location in ICQ where first introduced]
AE Planetary magnitudes from the American Ephemeris and Nautical
Almanac (for use with bright comets) [ICQ 4, 105]; also star
magnitudes from Astronomical Almanac
AT Arizona-Tonantzintla Catalog (publ. in July 1965 Sky & Telescope)
[ICQ 2, 6; 4, 8]
AU ASAS-3 V magnitudes, available from website:
http://archive.princeton.edu/~asas/asas3_catalog.html, and
click on "Search: V-band" under "Photometric Catalog"
(it is recommended that specific sequences and/or website
URLs be mentioned in descriptive data) [ICQ 25, 160]
BR V magnitude sequence for stars in the Coma cluster of galaxies
including Abell 1656 (Boerngen and Richter 1978, A.N. 299, 177)
BS Johnson V photometry by Brian Skiff at Lowell Observatory, with
data given at the World Wide Website URL
http://www.kusastro.kyoto-u.ac.jp/vsnet/catalogs/skiffchart.html;
because website material may be transient, the ICQ policy for
use of this source is to give additional information in the
descriptive information accompanying the published tabulated
data in the ICQ.
C Photovisual magnitudes from "Cape Photographic Catalogue for
1950.0", in Annals of the Cape Observatory, Vols. 17-22.
[ICQ 9, 142]
CA M44 standard sequence as published in Henden and Kaitchuck's
Astronomical Photometry (1982, New York: Van Nostrand Reinhold),
pp. 301-302. [ICQ 9, 99]
as published in Visual Astronomy of the Deep Sky (see ref. 'CL',
below), p. 250.
CE Open star cluster NGC 1647 photometry (8.5 < V < 16.4), in Visual
Astronomy of the Deep Sky, p. 252 (see ref. 'CL', below).
CF Open star cluster NGC 2129 photometry (11.2 < V < 16.1), in Visual
Astronomy of the Deep Sky, p. 254 (see ref. 'CL', below).
CG Open star cluster NGC 2422 (M47) photometry (7.7 < V < 14.3), in
Visual Astronomy of the Deep Sky, p. 256 (see ref. 'CL', below).
CH Open star cluster NGC 6494 (M23) photometry (9.3 < V < 13.9), in
Visual Astronomy of the Deep Sky, p. 258 (see ref. 'CL', below).
CI Open star cluster NGC 6823 photometry (9.4 < V < 16.0), in Visual
Astronomy of the Deep Sky, p. 260 (see ref. 'CL', below).
CJ Open star cluster NGC 6910 photometry (9.9 < V < 14.9), in Visual
Astronomy of the Deep Sky, p. 262 (see ref. 'CL', below).
CK Open star cluster NGC 7031 photometry (11.2 < V < 16.5), in Visual
Astronomy of the Deep Sky, p. 264 (see ref. 'CL', below).
CL Photometry by Hoag et al. (1961) from one of the open-star-cluster
charts as published in Visual Astronomy of the Deep Sky, by Roger
N. Clark (Cambridge Univ. Press, 1990), pp. 250-266.
CM Photovisual and photoelectric-V magnitudes from Cape Mimeograms
(Royal Observatory, Cape of Good Hope). [ICQ 9, 142]
CN Open star cluster NGC 7235 photometry (8.7 < V < 16.4), in Visual
Astronomy of the Deep Sky, p. 266 (see ref. 'CL', above).
CO UBV photometry for 39 stars in the range 11.7 < V < 18.7, from
"A New Stellar Standard Sequence in the Comet Cluster of Galax-
ies" (F. Boerngen and N. Richter 1978, Astron. Nach. 299, 117)
CR V magnitudes of 13 stars surrounding NGC 3627 (M66), as given by
Ciatti and Rosino (1977, A.Ap. 56, 62). The range in V is
13.8-16.9, and the stars are fairly red. [ICQ 11, 30]
CS Catalogue of Stellar Identifications (1979, Strasbourg). Large
compilation of many catalogues. For information, see F.
Ochsenbein et al. (1981), A.Ap. Suppl. 43, 259, and Ochsenbein
(1974), A.Ap. Suppl. 15, 215. The visual magnitudes with colons
(:) should be avoided if possible. [ICQ 10, 35]
D Dutch Comet Halley Handbook (E. P. Bus) [ICQ 7, 96]
E One of Everhart's 3 Selected Area charts (1984, Sky Telesc. 67, 28)
EA Selected Area 51: From Everhart (1984, Sky Telesc. 67, pp. 28-30).
EB Selected Area 57: From Everhart (1984, see EA, above) [ICQ 7, 51]
EC Selected Area 68: From Everhart (1984, see EA, above) [ICQ 7, 51]
FA V photometry by Harold Ables, U.S. Naval Observatory, Flagstaff,
"Region No. 6", unpublished (stellar V magnitude range 11.1-15.8
photoelectric and 13.7-21.6 electronographic). [ICQ 9, 99]
GA Guide Star Photometric Catalog - I, in Astrophysical Journal
Supplement Series, Volume 68, Number 1 (1988 September).
Contains nearly 1500 stars with V magnitudes and convenient
finder charts throughout the sky. [ICQ 10, 124; 15, 60]
*** NOTE: this is VERY different from the GSC on CD, which has
reference code 'HS' and which is a POOR source of comparison-star
magnitudes! ***
GP [apparently same as 'HE'; see below]
HD Henry Draper Catalog (Harvard Coll. Obs. Annals) [ICQ 2, 39]
HE Harvard E Regions (declination -45 deg), Kron-Cousins V photometry
for nine fields; stars range generally between 7 < V < 16
(Graham 1982, P.A.S.P. 94, 244) [ICQ 10, 124]
HI Hipparcos Input Catalogue (C. Turon et al. 1992, European Space
Agency Special Publication SP-1136; derived V magnitudes
(118,000 stars brighter than mag 13, with the distribution
peak around V = 9); see also HJ
HJ magnitudes in the Hipparcos photometric system, Hp (see code
HI, above); peak of Hp is closer to true visual than to
Johnson V, though it has a long red wing
HK H_p magnitudes from the Hipparcos Catalogue (ESA SP-1200).
HN Arne Henden's photometric sequences, which can be downloaded
from his computer at
ftp://ftp.nofs.navy.mil/pub/outgoing/aah/sequence
(and especially via R. Bouma at
http://www.shopplaza.nl/astro/vs-charts/ and via M. Simonsen
at http://home.earthlink.net/~joevp/index.html) -- but specific
sequences should be specified in descriptive data [ICQ 26, 8]
HP Harvard Photometry (Harvard College Obs. Annals) [ICQ 4, 8]
HR Harvard Revised Photometry (H.C.O. Annals) [ICQ 1, 42; 4, 8]
HV Johnson V magnitudes from Hipparcos Catalogue, ESA SP-1200.
JT Cousins VRI magnitudes of stars in M67 (M. Joner and B. Taylor
1990, PASP 102, 1004)
L Landolt V Photoelectric Sequences (AJ 78, 959) [ICQ 6, 37]
LA Landolt photoelectric sequences (1992, AJ 104, 340)
LB Landolt (1983, AJ 88, 439 and 853) sequences as published by
Christian Buil in ASTRONOMIE CCD (1989, Societe d'Astronomie
Populaire), p. 261
LC Landolt (1975, PASP 87, 379) magnitude sequence for 33 stars
near V1057 Cyg (V magnitude range 5.5-15.5)
MC Carlsberg Meridian Catalogue (1989). Volume 4. La Palma.
More than 50,000 stars with visual magnitudes down to V = 13;
do not use stars with magnitudes given to less than 0.01 mag.
ME V photometry by Tedesco, Tholen, and Zellner (1982, A.J. 87, 1585);
mag range 6-13 [ICQ 8, 77]
MK V magnitudes for M67 in LE GUIDE PRATIQUE DE L'ASTRONOMIE CCD
P. Martinez and A. Klotz 1994; Adagio press), p. 270
MP McCormick Photovisual Sequence (Univ. of Virginia) [ICQ 3, 15]
MS From "McCormick Photovisual Sequences", by C. A. Wirtanen and
A. N. Vyssotsky (1945, Ap.J. 101, 141-178). [ICQ 9, 142]
MT Visual magnitudes of stars in M67 as published by B. E. Schaefer
(1989, SKY TEL. 77, 332); after work by Racine and Gilliland.
MV From Publ. Leander McCormick Obs., Vol. VI, Part II, pp. 201-306
("Magnitudes and Coordinates of Comparison Stars in Regions of
Long-Period Variables, by S. A. Mitchell, 1935) or Vol. IX, Part
V, pp. 59-88 ("Sequences for Fifty Variable Stars", by Mitchell
and C. A. Wirtanen, 1939). [ICQ 9, 142]
NH North Polar Sequence as published by Henden and Kaitchuck (1982,
Astronomical Photometry, NY: Van Nostrand Reinhold), p. 305.
NN NGC 2129/6531/1342 cluster photometry, in Publ. U.S.N.O. Vol.
XVII, parts VII, VIII (1961), pp. 406, etc.. [ICQ 8, 130]
NO U.S.N.O. Photoelectric Photometry Catalogue [ICQ 2, 6; 4, 8]
NP North Polar Sequence (publ. by the A.A.V.S.O.); 3 charts showing
stars w/ useful range mv = 5.0 and fainter [ICQ 1, 17; 3, 7]
NS "Magnitudes and Colors of Stars North of +80 ", by Seares, Ross,
and Joyner (1941, Carnegie Inst. Publication 532) [ICQ 4, 80]
OB magnitudes for faint cluster stars from S. C. Odewahn, C. Bryja,
and R. M. Humphreys (1992), PASP, 104, 553 [used by
Spacewatch beginning 1999 Sept. 29, replacing FA; ICQ 123]
PA M45 sequence, Johnson & Mitchell (1958, Ap.J. 128, 31) [ICQ 8, 77]
PB Pleiades chart in Sky and Telescope 70, 465 (1985). [ICQ 8, 77]
PC Pleiades sequence, Henden and Kaitchuck (1982, Astronomical Photo-
metry; N.Y.: Van Nostrand Reinhold), pp. 298-300 [ICQ 8, 130]
PI IC 4665 sequence as found in Henden and Kaitchuck (1982,
Astronomical Photometry, New York: Van Nostrand Reinhold),
pp. 302-304. [ICQ 10, 35]
RB "Photoelectric Magnitudes and Colours of Southern Stars",
A. W. J. Cousins and R. H. Stoy (1963), in Royal Observatory
Bulletin No. 64 (Royal Greenwich Obs.), Series E3, pp. E101-E248.
[ICQ 9, 142]
RC "Standard Magnitudes in the E Regions", A. W. J. Cousins and R.
H. Stoy (1962), in Royal Observatory Bulletin No. 49 (Royal
Greenwich Obs.), Series E2, pp. E1-E59. [ICQ 9, 142]
SD V magnitudes of members of the globular cluster M15 in the range
13 < V < 22 [and also nearby field stars for 40 stars
of mag 7.64, 10.42-11.15, and 12.9 < V < 18.8],
by A. Sandage (1970, Ap.J. 162, 841)
SE V magnitudes of 134 stars of the II Persei Association (stars of
spectral types A and B, mag range 5.1-11.4;
C. K. Seyfert et al., Ap.J. 132, 58). [ICQ 11, 30]
SK Brian Skiff's compilation of magnitudes as part of the LONEOS
project (Lowell Observatory), appearing via Internet access
at ftp://ftp.lowell.edu/pub/bas/starcats/loneos.phot
(as of 9/25/01, containing about 33000 stars throughout
the sky from some 600 published sources -- mostly professional
astronomy journal articles); though magnitude range goes
from V = 7.4 to V = 22.9, only about 40 stars in this list
are brighter than mag 9.0 (but generally a good source of V
magnitudes for stars fainter than mag 10 or 11)
SM V magnitudes from "A Visual Atlas of the Small Magellanic Cloud",
by Mati Morel (1989), Rankin Park, N.S.W., Australia
SP Skalnate-Pleso Atlas Catalog (Atlas Coeli Cat.) [ICQ 2, 6; 4, 10]
SS Various regions covering declination -60 deg to +10 deg, with
stars having general range 12 < V < 24; Stobie et al. (1985),
Astron. Astrophys. Suppl. Ser. 60, 503
SW Four half-degree fields with finder charts and UBV photometry,
range 10 < V < 15 (except field IV, which has a gap between
11.5 < V < 13.5), published by W. Saurer et al. (1992) in
Astron. Astrophys. Suppl. Ser. 93, 553. The four fields
average about 40 stars each, roughly centered at the following
R.A. and Decl. (B1950.0): I, 1h27m, +58.2 deg; II, 3h24m,
+45.2 deg; III, 7h15m, -10.1 deg; IV, 21h31m, +50.2 deg.
TA Comparison-star magnitudes from "The Amateur Sky Survey"
(TASS), which has data available at the website URL
http://www.tass-survey.org/ [ICQ No. 133]
TG CCD magnitudes on the Thuan-Gunn system; comparison standard
stars in Thuan and Gunn (1976, PASP 88, 543).
TI Tycho Input Catalogue; more than three million stars brighter
than V = 12.1 prepared for the needs of the Tycho mission
(Hipparcos satellite; see D. Egret et al. 1992, Astron.
Astrophys. 258, 217); available upon request from the
Strasbourg Data Center (France; e-mail address
TJ Tycho Catalogue Johnson V magnitudes from ESA SP-1200.
TK Tycho-2 Catalogue (Hog et al. 2000, A.Ap., in press);
NOTE: *only* Tycho-2 V_T magnitudes (labeled VT)
from the *main* catalogue should be used. The
supplements contain a mix of V-like magnitudes
from the original Tycho catalogue and should not
be taken from here.
TS Field of 13 stars (R.A. 22h02m, Decl. -19.1 deg, equinox 1950.0),
V magnitudes with finding chart, 9.7 < V < 19.2, by Tritton
et al. (1984), MNRAS 206, 843-847.
TT Tycho/Hipparcos Catalogue V_T magnitudes from ESA SP-1200.
VG Japanese variable-star charts edited by K. Gomi and based on
charts drawn by Y. Kawanishi, publ. in 1970 by Koseisha Co.
as a spiral-bound book; its preface states that the magnitudes
of comparison stars are taken from Harvard Annals (Vols. 37,
50, 54, and 57) and from Skalnate Pleso II (Atlas Coeli).
Akimasa Nakamura, who reported this reference to the ICQ,
says that his comparison of Gomi charts with AAVSO charts
show that the comparison-star magnitudes are very close to
each other.
Y Yale Bright Star Catalogue [ICQ 1, 42; 4, 8]
YF Yale Bright Star Catalogue, fourth edition (should now be used
instead of earlier editions)
YG Yale Bright Star Catalogue, fifth edition
*** Sources NOT recommended, but which may be used (with caution)
if Recommended Sources are not available:
AA A.A.V.S.O. Variable Star Atlas [ICQ 4, 6]
AC Charts of the Amer. Assn. of Var. Star Observers [ICQ 4, 7]
Note, however, that the AAVSO does have numerous good charts, and
the AAVSO charts for the North Polar Sequence are highly recommended.
AP Atlas Photometrique des Constellations (1948), by Antoine Brun
(has stars to mag 7.5 labeled with Harvard photometry
magnitudes) [ICQ 5, 24]
AS AAVSO chart for M81 (NGC 3031) in Ursa Major, which was closely
scrutinized and revised during April and May 1993 as a result
of SN 1993J. The revised sequence, which was published in the
April 1993 issue of the ICQ, has a good sequence for the range
10.3 < V < 15.5. [ICQ 15, 60; 15, 102]
FD R magnitudes of M13 stars as published in "A photoelectric BVRI
sequence in the field of the globular cluster NGC 6205 (M13)",
by D. Forbes and P. C. Dawson (1986), PASP 98, 102-103.
FG from variable star charts published in *A Field Guide to the Stars
and Planets*, by D. H. Menzel and J. M. Pasachoff (part of the
Peterson Field Guide Series); charts by Wil Tirion for SS Cyg
(visual mag 5.1-11.4), R CrB (7.5-12.6), Algol (2.9-5.5), beta
Lyr, and Mira (3.5-9.2) are given on pages 158-161 of the second
edition and pages 198-201 of the third ed. (magnitude source is
not specified, but probably AAVSO)
LM V magnitudes from "A Visual Atlas of the Large Magellanic Cloud",
by Mati Morel (1983), Rankin Park, New South Wales [ICQ 10, 67]
ML V magnitudes on chart of Large Magellanic Cloud by Mati Morel
(apparently same as LM)
MM V magnitudes on chart of Small Magellanic Cloud by Mati Morel
(apparently same as SM)
OH From listing of bright stars in Observers' Handbook, R.A.S.C.
[ICQ 7, 51]
PK From the Soviet Program for Comet Halley; Dr. Klim Churyumov,
Kiev University, describes the method as follows (edited):
Comparison stars were noted on the Palomar Sky Survey prints;
the visual magnitudes of these stars were determined by
comparison with standards stars from the galactic cluster
NGC 2129 (V magnitudes taken from the paper by Hoag et al.
in Publ. U.S.N.O., Second Series, Vol. XVII, Part VII, pages
406 and 518, 1961). The visual magnitudes were determined
by use of the formula mv = V + 0.16(B-V).
S Smithsonian Astrophysical Obs. Star Catalog [ICQ 1, 17; 4, 9]
ONLY FOR STARS OF VISUAL MAGNITUDE 9.0 OR BRIGHTER!!
SA M67 sequence by R. E. Schild (1983, PASP 95, 1021), Kron-Cousins
magnitudes [ICQ 10, 35]
SC Sky Catalogue 2000.0 (Sky Publishing; stars of magnitude
V <8> 4.5 mag [ICQ 10, 35]
RA Annual Ephemeris of the Royal Astronomical Society of Canada (not
recommended, even for bright comets) [ICQ 5, 64]
TB Supernova Search Charts, by G. D. Thompson and J. T. Bryan, Jr.
(1989, Cambridge University Press)
V Variable star charts from recognized sources [the specific charts
should be stated in detail]
Sources not yet classified (use only with caution, making sure to have
comparison-star magnitudes of the proper bandpass):
AG Astronomisches Gesellschaft Katalog [ICQ 2, 6]
AH G. D. Roth's Astronomy: A Handbook, p. 534 (chart of the Pleiades)
[ICQ 6, 64]
data in the ICQ.
YZ Yale Zone catalogue
Sources that should never be used:
Old New
Key Key Source [+ location in ICQ where first introduced]
A Charts or Atlas of the AAVSO [AC or AA should be used]
AN Comparison-star sequences as published by M. Beyer in articles in
Astron. Nachrichten [used only for Beyer's data]
AO USNO (S)A1.0 catalogue R magnitudes, from the first editions
of this catalogue; not recommended because magnitudes may
be off by 0.5 mag or more due to photographic calibration
errors, but CCD astrometric comet observers are using them
due to convenience; see more information on the World Wide
Web at http://ftp.nofs.navy.mil/projects/pmm/readpht.v10
T UA Atlases Borealis, Eclipticalis, Australis [ICQ 2, 6]
C, CP UC Cape Photographic Catalogs [ICQ 1, 42; 4, 63]
UL Specific comet or planet mentioned as magnitude reference, but
comparison object not above horizon at same time as comet
OR no catalog listed [ICQ 7, 51]
M UM Magnitudes of galaxies, nebulae, etc. [ICQ 2, 6]
R UN Norton's Atlas [ICQ 2, 39; 4, 62]
UO USNO A2.0 catalogue R magnitudes; not recommended because
magnitudes may be off by 0.5 to 2 full magnitudes or more
due to photographic calibration errors, but CCD astrometric
comet observers are using them due to convenience
I, Q UP Any standard photographic atlas (e.g., Falkauer, Stellarium)
[ICQ 3, 15; 2, 59]
[no code] PPM catalogue (Roeser et al.); mostly photographic magnitudes
J, RC UR Revue des Constellations [ICQ 5, 24; 5, 64]
US Skalnate Pleso Atlas [ICQ 7, 51]
X UX Specific stars quoted, no catalogue given [ICQ 2, 39]
Добавлено: Ср Сен 10, 2014 22:14 Заголовок сообщения: |
| Код: | | Это область альфа Персея. |
В источнике для звезд сравнения (графа RF) указываем SE.
Звезда и ее номер указан в первой колонке, далее идет блеск (V) и спектральный класс звезды. Чем ближе мы к спектральному классу G, тем точнее оценка блеска кометы. Желательно не применять для оценки блеска комет красные звезды.
На втором и третьем снимке ниже идут номера звезд от 1 до 42, потом от 42 до 59.... Минимальный блеск звезды 11.4 m, максимальный 1.86 m.
| Источник звезд сравнения = SE, указываем в графе RF при оформлении наблюдений. |
49.28 KB |
5371 раз(а) |
Источник звезд сравнения = SE, указываем в графе RF при оформлении наблюдений. »»»
Добавлено: Ср Сен 10, 2014 22:16 Заголовок сообщения: |
Стандарт SE. Звезда 1-42....
| Стандарт SE. Звезда 1-42.... |
14.97 KB |
5369 раз(а) |
Стандарт SE. Звезда 1-42.... »»»
Добавлено: Ср Сен 10, 2014 22:18 Заголовок сообщения: |
Стандарт SE. Звезда 42 - 59....
| Стандарт SE. Звезда 42 - 59. |
6.44 KB |
5367 раз(а) |
Стандарт SE. Звезда 42 - 59. »»»
Добавлено: Ср Сен 10, 2014 22:41 Заголовок сообщения: |
Звездный стандарт PA (Плеяды)
| Звездный стандарт PA (Плеяды) |
100.68 KB |
5362 раз(а) |
Звездный стандарт PA (Плеяды) »»»
Добавлено: Ср Сен 10, 2014 22:52 Заголовок сообщения: |
Звездный стандарт PA. (Плеяды - M45)
Звезда 1 - 24.
Самая слабая звезда всего стандарта +14.8m, самая яркая звезда стандарта +2.7m. В графе источник звезд(RF) сравнения указываем PA.
| Звездный стандарт PA. Звезда 1 - 24. |
4.52 KB |
5358 раз(а) |
Звездный стандарт PA. Звезда 1 - 24. »»»
Добавлено: Ср Сен 10, 2014 22:54 Заголовок сообщения: |
Звезда 24 - 47.
| Звездный стандарт PA. Звезда 24 - 47. |
4.22 KB |
5355 раз(а) |
Звездный стандарт PA. Звезда 24 - 47. »»»
Добавлено: Ср Сен 10, 2014 23:04 Заголовок сообщения: |
| Код: | | И еще один стандарт - WC. |
Это окрестности переменной звезды Y Tauri. Самая яркая звезда пригодная для для визуальных оценок комет + 6.3m, а самая слабая - 10.6m.
При указании источника звезд сравнения пишем в графе RF ----> WC
26.83 KB |
5349 раз(а) |
Звездный стандарт WC. »»»
