Надо уметь переносить то, чего нельзя избежать. /М. Монтень/
Новая Центавра 2013
На страницу 1, 2, 3, 4, 5, 6, 7, 8  След.
Добавлено: Сб Дек 07, 2013 21:35    Заголовок сообщения: Новая Центавра 2013 Ответить с цитатой
МНЕ ПРИШЛО СООБШЕНИЕ ...
Кидайте в переводчит все кто не знает английского..))
Я посмотрел - Район вспышки Новой Центавра у меня просматривается на 2-х камерах в предрассветных лучах... ))) О! - Sechr Gut !!! Сейчас промеряем ....
AAVSO Alert Notice 492: Nova Centauri 2013 = PNV J13544700-5909080
От кого: [hidden]
Кому: [hidden]
4 декабря, 20:59
December 4, 2013
Event: Nova in Centaurus = Nova Cen 2013 = PNV J13544700-5909080
Discovered by: John Seach (Chatsworth Island, NSW, Australia)
Discovery magnitude: unfiltered magnitude 5.5 using a DSLR with
50-mm lens
Discovery date: 2013 December 02.692 UT
Coordinates: R.A. 13 54 45.34 Decl. -59 09 04.2 (2000.0, K. Hornoch,
Astronomical Inst., Ondrejov, Czech Republic)
Spectra: Low-resolution spectra obtained by Malcolm Locke
(Christchurch, New Zealand) on Dec. 03.3776 UT and by Rob Kaufman
(White Cliffs, NSW, Australia) on Dec. 03.621 UT show strong Ha
and Hb emission lines, indicating the object is a nova. Spectra
URLs below.
Charts: Charts for Nova Cen 2013 may be created using the AAVSO
Variable Star Plotter (VSP) at http://www.aavso.org/vsp.
Selecting an 'A' scale chart will give the widest choice of
comparison stars for this very bright object. Choosing the
Binocular chart option along with the 'A' scale will result in a
less cluttered field and is recommended. Alternatively, setting
the 'Field' option at 580 (arcmin) and 'Magnitude limit' at 8.0
will give a smaller field of view but still provide many bright
comparison stars.
At present, however, Nova Cen 2013 has brightened beyond the
comparison stars available on even an 'A' scale chart. It is
recommended that observers use:
41 = eta Cru (HD 105211) V=4.142, B-V=+0.353
40 = zeta Cru (HD 106983) V=4.043; B-V=-0.174
39 = gamma Mus (variable with 0.02 mag. range) V=3.85; B-V=-0.155
Electronic observers are cautioned to be careful not to saturate
the nova. Since the comparison stars are mostly fainter than the
nova, it is recommended to take short exposures and stack them so
as to achieve a good S/N for the comparison stars without saturating
the nova. Electronic observers should not use gamma Mus.
Observations reported to the AAVSO:
2013 Nov. 26.69 UT, <11 (Seach);
27.8, <7 (PEX, A. Pearce, Nedlands, W. Australia);
Dec. 01.338, <6.3 R +/-0.2 (HOK, K. Hornoch, remotely with the La Silla
Danish 1.54-m telescope, reported via CBET 3732);
02.340, 5.9 R +/-0.2 (Hornoch, reported via CBET 3732);
03.23890, 5.33 (OSE, S. Otero, Buenos Aires, Argentina);
03.28819, 5.4 (AAX, A. Amorim, Florianopolis, Brazil);
03.340, 4.8 R +/-0.2 (Hornoch, reported via CBET 3732);
03.40000, 5.3 (ERW, R. Evans, Invercargill, New Zealand);
03.581, 5.0 (WPX, P. Williams, Heathcote, NSW, Australia);
03.68, 5.0 U (E. Guido, N. Howes, and M. Nicolini, remotely
using the 0.50-m f/6.8 astrograph + CCD + focal reducer of
iTelescope network (MPC Code Q62 - Siding Spring, Australia));
03.718, 5.0 (CMQ, P. Camilleri, Warners Bay, NSW, Australia);
03.743, 4.7 (Pearce);
03.8243, 4.6 (Pearce);
04.27570, 4.28 (Otero);
04.28333, 4.2 (SGQ, C. Sigismondi, Rome, Italy);
04.29306, 4.3 (NTA, T. Napoleao, Sao Paulo, Brazil);
04.29323, 4.6 R (BJB, J-G. Bosch, Collonges/Salve, Switzerland,
remotely using T400/8, Spaceobs A.Maury MPCW96);
04.29722, <4.50 U (OEDA, E. Oliveira, Sao Paulo, Brazil);
04.34236, 4.35 (GAJ, J. Garcia, Rama Caida, Mendoza, Argentina);
Submit observations: Until a permanent GCVS name is assigned,
please submit observations to the AAVSO International Database
using the name NOVA CEN 2013.
Notes:
a. Announced on IAU CBAT Central Bureau Electronic Telegram 3732
(Daniel W. E. Green, ed.)
b. The object was designated PNV J13544700-5909080 when it was
posted on the Central Bureau's TOCP webpage
(http://www.cbat.eps.harvard.edu/unconf/tocp.html).
c. Spectra images
- Malcolm Locke (Christchurch, New Zealand) at
http://www.flickr.com/photos/malclocke/11187714294/#in/photostream/
- Rob Kaufman (KBJ, White Cliffs, NSW, Australia) at
http://i727.photobucket.com/albums/ww271/Rob_Kau/PNVJ13544700-5909080spectrum03Dec2013.jpg
d. K. Hornoch (Astronomical Institute, Ondrejov) gives position end
figures 45.34s, 04.2" from R-band images taken with the Danish
1.54-m telescope at La Silla on Dec. 3.361 UT; his comparison of
his stacked R-band image (left) and a DSS red image (right) is
posted at http://www.asu.cas.cz/~asteroid/PNV_J13544700-5909080.png.
J. Oey, P. Camilleri, and H. Williams (Blue Mountains Obs. using
a 0.35-m F/5.9 + CCD) give position end figures 45.37s 04.8" (2000)
from an image taken 2013 Dec 03.6895 UT. E. Guido, N. Howes, and
M. Nicolini give position end figures 45.22s, 04.5" (UCAC-3
reference stars); image and animation at http://bit.ly/19f1M2l.
J.-G. Bosch gives position end figures 45.21s 04.3" from images
obtained remotely (T400/8, Spaceobs A.Maury MPCW96) on Dec. 04.29323.
e. Guido, Howe, and Nicolini, and Hornoch report that the nearest
star (located at 1.538 arcsecond from the transient) to this
position in the USNO-B1.0 catalogue is USNO-B1.0 0308-0442031,
mag. B2=15.52 R2 =15.12. B. Skiff (Lowell Obs.) reports preferred
coordinates (2000.0) for this possible progenitor are
13 54 45.35 -59 09 04.1 (UCAC2) and 13 54 45.35 -59 09 04.1 (2MASS).
Skiff also notes that there is an XMM-Newton x-ray source 2" away.
f. APASS images centered on the nova position
- 1x1 degree APASS 2013 Dec 03 UT V band N up E left
http://www.aavso.org/sites/default/files/nova_cen_2013v.jpg
- close-up of APASS Dec 03 V image N up E left
http://www.aavso.org/sites/default/files/nova_cen_2013_13v.jpg
- APASS image from 2012 centered on the nova position V band N up E left
http://www.aavso.org/sites/default/files/nova_cen_2013_12v.jpg
Henden comments that there is a close companion to the NE that
will be a problem as the nova fades, but is not a factor now.
Congratulations to John Seach on his latest discovery!
This AAVSO Alert Notice was prepared by Elizabeth O. Waagen and
Sebastian Otero.
SUBMIT OBSERVATIONS TO THE AAVSO
Information on submitting observations to the AAVSO may be found at:
http://www.aavso.org/webobs
ALERT NOTICE ARCHIVE AND SUBSCRIPTION INFORMATION
An Alert Notice archive is available at the following URL:
http://www.aavso.org/alert-notice-archive
Subscribing and Unsubscribing may be done at the following URL:
http://www.aavso.org/observation-notification#alertnotices
Please support the AAVSO and its mission --
Join or donate today: http://www.aavso.org/apps/donate
Редактировать сообщение
Добавлено: Сб Дек 07, 2013 21:35    Заголовок сообщения: Ответить с цитатой
Итак, на основании работы программы "All Sky Beobachter" в белорусском проекте "Астроблокнот" сделаны измерения роста блеска Nova Cen 2013 (участники - Дмитрий Акулич и Наталья Ефременко).
Name JD CalendarDate Mag Err Filter Comp Label Comp Mag Check Label Check Mag Chart Trans. Comment Codes Notes
2 edit delete NOVA CEN 2013 2456631.85486 2013 Dec 5.3549 3.62 Vis. SAO 241047 SAO 251862 K N black-and-white photo - all-sky camera limit=5.3
3 edit delete NOVA CEN 2013 2456631.82986 2013 Dec 5.3299 3.9 Vis. SAO 251852 - K N black-and-white photo - all-sky camera limit=5.0
4 edit delete NOVA CEN 2013 2456631.11806 2013 Dec 4.6181 4.4 Vis. SAO 251852 - K N black-and-white photo - all-sky camera limit=5.0
5 edit delete NOVA CEN 2013 2456631.24028 2013 Dec 4.7403 4.3 Vis. SAO 252531 - K N black-and-white photo - all-sky camera limit=5.5
6 edit delete V1369 Cen 2456630.82708 2013 Dec 4.3271 4.52 Vis. SAO 240645 SAO 252531 K N black-and-white photo - all-sky camera limit=7.0
7 edit delete NOVA CEN 2013 2456629.83472 2013 Dec 3.3347 5.25 Vis. SAO 241673 SAO 241080 K N black-and-white photo - all-sky camera limit=7.0
8 edit delete NOVA CEN 2013 2456629.24306 2013 Dec 2.7431 5.55 Vis. SAO 241080 SAO 241096 K N black-and-white photo - all-sky camera limit=7.1
9 edit delete NOVA CEN 2013 2456628.83333 2013 Dec 2.3333 6.42 Vis. SAO 241114 SAO 241142 K N black-and-white photo - all-sky camera limit=7.6 NOVA CEN 2013 !!!!!!!!!!!!!!!!!!!!!
1 edit delete NOVA CEN 2013 2456628.78125 2013 Dec 2.2813 6.5 Vis. SAO 241080 TYC 8635-3300-1 K N black-and-white photo - all-sky camera limit=6.9m NOVA CEN 2013 !?
10 edit delete V1369 Cen 2456628.23264 2013 Dec 1.7326 <7.2 Vis. SAO 241114 SAO 241142 K N black-and-white photo - all-sky camera limit=7.3
11 edit delete NOVA CEN 2013 2456627.82778 2013 Dec 1.3278 <6.7 Vis. SAO 241114 - K N black-and-white photo - all-sky camera limit=6.8
НОВАЯ ЦЕНТАВРА НА СНИМКАХ ОЛЛ-СКАЙ ЗАФИКСИРОВАНА РАНЕЕ автора открытия ....
Добавлено: Сб Дек 07, 2013 21:36    Заголовок сообщения: Ответить с цитатой
Hi Ivan,
Those observations have been changed to CV.
Minsk seems to be ideally placed for catching bright novae! We are too far north to see if from here (I am in Ireland now).
Best regards,
Sara
ПЕРЕВОД
Привет Иван,
Эти замечания были изменены, чтобы резюме.
Минск, кажется, идеально подходит для ловли яркий новых звезд! Мы слишком далеко на север, чтобы увидеть, если отсюда (я нахожусь в Ирландии в настоящее время).
С уважением,
Сара
Добавлено: Сб Дек 07, 2013 21:39    Заголовок сообщения: Новая Центавра 2013 Ответить с цитатой
2 маленьких кропа с одной олл-скай камеры...
Стрелкой указана на втором Новая...
Изображение ---- зеркально-перевёрнутое ...
 Размер файла:  23.51 KB
 Просмотрено:  20870 раз(а)
 Размер файла:  16.72 KB
Добавлено: Сб Дек 07, 2013 22:42    Заголовок сообщения: Ответить с цитатой
То есть Вы им даже не говорите что за камеры? facepalm!
Добавлено: Сб Дек 07, 2013 22:59    Заголовок сообщения: Новая Центавра 2013 Ответить с цитатой
График блеска Новой ...
Showing 124 observations for V1369 Cen from 27 observers
Из них - с 01 по 05 декабря - пока что 11 наблюдений И.С. Брюханова ... Другие дни - пока не реализованы - промеряю ...))
P.S. Они знают что это за камеры ..)
 Размер файла:  65.95 KB
 Просмотрено:  20840 раз(а)
Добавлено: Вс Дек 08, 2013 23:10    Заголовок сообщения: Ответить с цитатой
Иван Брюханов
Здравствуйте Георгий Михайлович!
02/12/2013 вспыхнула Новая Центавра около Бэта Центавра...
В то время как отдельные наблюдатели просмотрели звезду 1-2 раза _ Брюханов сегодня за вечер и ночь просмотрел и измерил её блеск и отправил в ААВСО 11 точек на график, зафиксировав дважды более ранние моменты Новой в блеска около 6.5 величины, чем первооткрыватель....)))
17:56
Георгий Рудницкий
Иван Сергеевич, пишите в АЦ, быстро опубликуем!
Добавлено: Пн Дек 09, 2013 21:04    Заголовок сообщения: Ответить с цитатой
Новая порция измерений блеска Новой с 06/12/2013 по 09/12/2013
1 edit delete NOVA CEN 2013 2456636.24444 2013 Dec 9.7444 4.09 Vis. SAO 240366 SAO 240645 K N black-and-white photo - all-sky camera limit=6.0
2 edit delete NOVA CEN 2013 2456636.23264 2013 Dec 9.7326 4.05 Vis. SAO 240366 SAO 240645 K N black-and-white photo - all-sky camera limit=6.8
3 edit delete NOVA CEN 2013 2456635.85069 2013 Dec 9.3507 3.89 Vis. SAO 251862 SAO 240366 K N black-and-white photo - all-sky camera limit=6.5
4 edit delete NOVA CEN 2013 2456635.82292 2013 Dec 9.3229 3.88 Vis. SAO 251852 SAO 240366 K N black-and-white photo - all-sky camera limit=7.0
5 edit delete NOVA CEN 2013 2456634.83750 2013 Dec 8.3375 3.84 Vis. SAO 251852 SAO 240366 K N black-and-white photo - all-sky camera limit=7.0
6 edit delete NOVA CEN 2013 2456634.84861 2013 Dec 8.3486 3.99 Vis. SAO 251852 SAO 240366 K N black-and-white photo - all-sky camera limit=6.4
7 edit delete V1369 Cen 2456633.83333 2013 Dec 7.3333 3.61 Vis. SAO 252853 SAO 251862 K N black-and-white photo - all-sky camera limit=7.0
8 edit delete V1369 Cen 2456633.85278 2013 Dec 7.3528 3.75 Vis. SAO 252853 SAO 251862 K N black-and-white photo - all-sky camera limit=6.5
9 edit delete V1369 Cen 2456634.19722 2013 Dec 7.6972 3.79 Vis. SAO 252853 SAO 251862 K N black-and-white photo - all-sky camera limit=7.0
10 edit delete V1369 Cen 2456634.26042 2013 Dec 7.7604 3.73 Vis. SAO 252853 SAO 251862 K N black-and-white photo - all-sky camera limit=6.5
11 edit delete NOVA CEN 2013 2456633.20833 2013 Dec 6.7083 3.66 Vis. SAO 252853 SAO 251862 K N black-and-white photo - all-sky camera limit=7.0
12 edit delete NOVA CEN 2013 2456632.84375 2013 Dec 6.3438 3.58 Vis. SAO 252853 SAO 251862 K N black-and-white photo - all-sky camera limit=7.0
Добавлено: Пн Дек 09, 2013 21:22    Заголовок сообщения: Новая Центавра 2013 Ответить с цитатой
06/12/2013 - 09/12/2013
 Размер файла:  72.14 KB
 Просмотрено:  20730 раз(а)
Добавлено: Вт Дек 10, 2013 17:40    Заголовок сообщения: Новая Центавра 2013 Ответить с цитатой
1 edit delete NOVA CEN 2013 2456636.85208 2013 Dec 10.3521 4.03 Vis. SAO 240366 SAO 240645 K N black-and-white photo - all-sky camera limit=6.0
2 edit delete NOVA CEN 2013 2456636.83542 2013 Dec 10.3354 3.99 Vis. SAO 240366 SAO 240645 K N black-and-white photo - all-sky camera limit=7.0
3 edit delete NOVA CEN 2013 2456636.81389 2013 Dec 10.3139 3.9 Vis. SAO 240366 SAO 240645 K N black-and-white photo - all-sky camera limit=7.0
4 edit delete NOVA CEN 2013 2456636.25000 2013 Dec 9.7500 4.14 Vis. SAO 240366 SAO 240645 K N black-and-white photo - all-sky camera limit=6.0
Добавлено: Вт Дек 10, 2013 17:44    Заголовок сообщения: Ответить с цитатой
Новая Центавра 2013 - явно не спешит слабеть ...
Это уж точно не быстрая Новая и не похожа на Новую Дельфина 2013
:-X
MarsianskiAlien
Благодарности: 12
Добавлено: Ср Дек 11, 2013 02:32    Заголовок сообщения: Ответить с цитатой
Возможно, будет похожа на Новую Геркулеса 1934 года..
Добавлено: Ср Дек 11, 2013 12:46    Заголовок сообщения: Ответить с цитатой
Да, Ваня ...
Я не могу себе приписывать снижение блеска Новой Центавра - она явно на рассвете "пучится-ярчает" как любая красная переменная...
Т.е. звезда цветная - наверняка избыток инфракраса как тогда у Новой Дельфина - чёй то вкладывает ...))) Так как все эти снимки без фильтра и внесистемные, а матрицы пик чувствительности имеют в красных лучах ...
Но это однозначно не тип NA.
Relax!
Добавлено: Сб Дек 14, 2013 19:59    Заголовок сообщения: Новая Центавра 2013 Ответить с цитатой
НОВАЯ ПОРЦИЯ НАБЛЮДЕНИЙ 10-14 декабря 2013
Новая явно ярчает ...
1 edit delete NOVA CEN 2013 2456641.18750 2013 Dec 14.6875 3.53 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=5.0
2 edit delete NOVA CEN 2013 2456640.85139 2013 Dec 14.3514 3.41 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.0
3 edit delete NOVA CEN 2013 2456640.81597 2013 Dec 14.3160 3.45 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.0
4 edit delete NOVA CEN 2013 2456640.77778 2013 Dec 14.2778 3.5 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=5.0
5 edit delete NOVA CEN 2013 2456640.26667 2013 Dec 13.7667 3.55 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=5.0
6 edit delete NOVA CEN 2013 2456640.24167 2013 Dec 13.7417 3.58 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.0
7 edit delete NOVA CEN 2013 2456640.21875 2013 Dec 13.7188 3.61 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.8
8 edit delete NOVA CEN 2013 2456640.20139 2013 Dec 13.7014 3.65 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.0
9 edit delete NOVA CEN 2013 2456639.85556 2013 Dec 13.3556 3.65 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=5.0
10 edit delete NOVA CEN 2013 2456639.83542 2013 Dec 13.3354 3.58 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.0
11 edit delete NOVA CEN 2013 2456639.81528 2013 Dec 13.3153 3.62 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.8
12 edit delete NOVA CEN 2013 2456639.79653 2013 Dec 13.2965 3.8 Vis. SAO 251862 SAO 240366 K N black-and-white photo - all-sky camera limit=6.9
13 edit delete NOVA CEN 2013 2456639.24653 2013 Dec 12.7465 3.77 Vis. SAO 251862 SAO 240366 K N black-and-white photo - all-sky camera limit=5.5
14 edit delete NOVA CEN 2013 2456639.22917 2013 Dec 12.7292 3.7 Vis. SAO 251862 SAO 240366 K N black-and-white photo - all-sky camera limit=6.8
15 edit delete NOVA CEN 2013 2456639.20139 2013 Dec 12.7014 3.85 Vis. SAO 251862 SAO 240366 K N black-and-white photo - all-sky camera limit=6.5
16 edit delete NOVA CEN 2013 2456639.17361 2013 Dec 12.6736 3.9 Vis. SAO 251862 SAO 240366 K N black-and-white photo - all-sky camera limit=6.5
17 edit delete NOVA CEN 2013 2456638.84375 2013 Dec 12.3438 3.69 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.0
18 edit delete NOVA CEN 2013 2456638.82500 2013 Dec 12.3250 3.6 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.0
19 edit delete NOVA CEN 2013 2456638.80694 2013 Dec 12.3069 3.64 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.5
20 edit delete NOVA CEN 2013 2456638.21944 2013 Dec 11.7194 3.67 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=5.0
21 edit delete NOVA CEN 2013 2456638.23403 2013 Dec 11.7340 3.7 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=5.5
22 edit delete NOVA CEN 2013 2456638.24444 2013 Dec 11.7444 3.75 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.0
23 edit delete NOVA CEN 2013 2456637.85000 2013 Dec 11.3500 3.65 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=6.0
24 edit delete NOVA CEN 2013 2456637.84028 2013 Dec 11.3403 3.68 Vis. SAO 251862 SAO 240366 K N black-and-white photo - all-sky camera limit=7.0
25 edit delete NOVA CEN 2013 2456637.78333 2013 Dec 11.2833 3.84 Vis. SAO 251862 SAO 240366 K N black-and-white photo - all-sky camera limit=6.0
26 edit delete NOVA CEN 2013 2456637.18958 2013 Dec 10.6896 4.05 Vis. SAO 240366 - K N black-and-white photo - all-sky camera limit=5.0
27 edit delete NOVA CEN 2013 2456637.18542 2013 Dec 10.6854 3.77 Vis. SAO 239791 SAO 240645 K N black-and-white photo - all-sky camera limit=6.0
28 edit delete NOVA CEN 2013 2456637.18681 2013 Dec 10.6868 4.0 Vis. SAO 240366 - K N black-and-white photo - all-sky camera limit=6.0
29 edit delete NOVA CEN 2013 2456637.18819 2013 Dec 10.6882 3.8 Vis. SAO 239791 SAO 240645 K N black-and-white photo - all-sky camera limit=6.0
30 edit delete NOVA CEN 2013 2456636.85208 2013 Dec 10.3521 4.03 Vis. SAO 240366 SAO 240645 K N black-and-white photo - all-sky camera limit=6.0
 Размер файла:  85.95 KB
 Просмотрено:  20527 раз(а)
Добавлено: Сб Дек 14, 2013 20:36    Заголовок сообщения: Ответить с цитатой
Showing 289 observations for V1369 Cen from 34 observers
Из 289 всех наблюдений - 56 наблюдений личных ...
Добавлено: Сб Дек 14, 2013 22:37    Заголовок сообщения: Новая Центавра 2013 Ответить с цитатой
Ещё небольшой довесок за 14 декабря ...
1 edit delete NOVA CEN 2013 2456641.26042 2013 Dec 14.7604 3.36 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=5.1
2 edit delete NOVA CEN 2013 2456641.23264 2013 Dec 14.7326 3.38 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=5.2
3 edit delete NOVA CEN 2013 2456641.20833 2013 Dec 14.7083 3.52 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=5.0
Добавлено: Вс Дек 15, 2013 00:16    Заголовок сообщения: Ответить с цитатой
Никак не пойму этой системы - эти оллскай камеры - это что за они? Это ваши? Или "общественные"? С ограниченным доступом для узкого круга лиц или с неограниченным? Или платные?
Добавлено: Вс Дек 15, 2013 02:26    Заголовок сообщения: Ответить с цитатой
Бесплатные, картинки на web-страницах обновляются автоматически через равные промежутки времени (30-60 с в среднем). Используются, как правило, при обсерваториях. Просто нужно найти такие камеры. Wink
Добавлено: Вс Дек 15, 2013 14:00    Заголовок сообщения: Ответить с цитатой
bigol писал(а):
Никак не пойму этой системы - эти олл-скай камеры - это что за они? Это ваши? Или "общественные"? С ограниченным доступом для узкого круга лиц или с неограниченным? Или платные?
Обзорные метеорологические камеры всего неба работающие в онлайн-режиме и доступные всем ... Виталий всё правильно сказал.
Остаётся найти только КАЧЕСТВЕННЫЕ камеры с КАЧЕСТВЕННЫМИ фото ... Большинство - средненькие со слабым пределом ...
Есть камеры даже с архивами и с фото с фильтрами .. Но они закрыты ...
http://www.astronomy.ru/forum/index.php/topic,80015.0/all.html
Добавлено: Вс Дек 15, 2013 17:36    Заголовок сообщения: Новая Центавра 2013 Ответить с цитатой
Ещё измерения ... Пока только 1 камера (тучки, циррусы, Луна, измерения в просветы с хорошим качеством изображения ...
1 edit delete NOVA CEN 2013 2456641.85347 2013 Dec 15.3535 3.85 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=4.5 MOON!!
2 edit delete NOVA CEN 2013 2456641.80556 2013 Dec 15.3056 3.7 Vis. SAO 239791 SAO 240366 K N black-and-white photo - all-sky camera limit=4.5 MOON!!
Страница 1 из 8
