Уничтожение одного есть рождение другого. /Аристотель/
Наблюдения Квадрантид-2016 с помощью стратостата (20 км)
Добавлено: Сб Янв 09, 2016 19:45    Заголовок сообщения: Наблюдения Квадрантид-2016 с помощью стратостата (20 км) Ответить с цитатой
Друзья !
Смотрите уникальный эксперимент (давший результаты науке!)
На видео все метеоры отмечены кружкАми ..
Message: 1
Date: Thu, 7 Jan 2016 13:17:06 +0100
Subject: (meteorobs) Quadrantids 2016 from Spain, above the clouds
To: Meteor science and meteor observing <meteorobs>
Dear all,
I want to share the report of the Quadrantids 2016 from Spain. The weather
was terrible all across the Iberian Peninsula, however we managed to get
some nice meteors from over the clouds:
https://www.youtube.com/watch?v=-z3V8jpJwq8
We launched a stratospheric balloon and despite the weather conditions
(flight shortened to 8 useful minutes due to rain/ice) we recorded 7
meteors. The flight lasted 90 minutes and the ground track was around 150km
long. Maximum height was around 22km, though previous flights reached up to
32km (usual missions have 40-60 minutes with stable video).
After 5 years of launches, we finally sent a colour and full HD
videocamera. Previous attemps were sometimes failures (Geminids 2015,
Draconids 2011) and some others kind of success (Geminids 2012,
Camelopardalids 2014), but this time we are quite satisfied with the result
of the mission and we hope to share more videos like this.
I want to thank to quite some people of this list, specially for their
appropiate remarks and suggestions, specially at IMC meetings.
Best regards,
Paco Oca?a (on behalf of the mission team from UCM, SPMN and Daedalus)
-------------- next part --------------
petrovicch
Благодарности: 28
Добавлено: Сб Янв 09, 2016 23:11    Заголовок сообщения: Ответить с цитатой
Интересно, что там за камера у них?
Добавлено: Сб Янв 09, 2016 23:15    Заголовок сообщения: Ответить с цитатой
Примеры метеоров на роике на временных метках:
2м:30с
3м:10с
4м:16с
4м:54с
6м:40с
7м:00с
7м:08с
7м:11с
8м:00с
Добавлено: Сб Янв 09, 2016 23:34    Заголовок сообщения: Ответить с цитатой
Баловство Smile
Добавлено: Сб Янв 09, 2016 23:43    Заголовок сообщения: Ответить с цитатой
Вот что пишет автор:
Currently we are using an Evil camera with self recording system. We are
trying to get the manufacturer to have a collaboration with us. As we are
completely self-funded we prefer to wait before disclosing it. Anycase it
is an off-the-shelf product, comercial brand. Simply we don´t want to make
free publicity to the brand, but the idea of the project is to make it open
for other enthusiasts. The camera is controlled by a Raspberry Pi, and we
will release the software too. The configuration this time was ISO 20000,
full HD, exp. 1/50, 30 fps, Sigma 30mm f1.4.
If you are interested in figures, more or less the material for each
mission costs 4500€, and up to 3500€ are most of the times reusable for the
next one (if nothing fail... previous one ended up in Mediterranean Sea...).
petrovicch
Благодарности: 28
Добавлено: Вс Янв 10, 2016 01:03    Заголовок сообщения: Ответить с цитатой
Если я что-то понял из гугл-переводчика, то камеру они не "раскрывают". Пока коммерческая тайна. Может Кенон?
ME20F-SH, способна вести Full HD видеосъемку в условиях с минимальной освещенностью менее 0,0005 люкс (при настройки усиления на максимальный уровень 75 дБ, что эквивалентно чувствительности в ISO более 4 млн единиц)
Правда стоит она пару десятков тыщ вечнозеленых... Sad Very Happy Very Happy
 Размер файла:  29.5 KB
 Просмотрено:  9630 раз(а)
 Размер файла:  26.62 KB
ddd31ddd
Добавлено: Вс Янв 10, 2016 10:21    Заголовок сообщения: Ответить с цитатой
Там оптика Sigma 30mm f1.4
Sky-Watcher BK2001EQ5: NIKON 610, 3200.
ddd31ddd сейчас оффлайн  Посмотреть профиль Отправить личное сообщение
Добавлено: Вс Янв 10, 2016 15:31    Заголовок сообщения: Ответить с цитатой
Насколько я понимаю - они уже минимум лет 5 ставят такие опыты ..
Насчёт камеры - у них ответ такой:
Date: Fri, 8 Jan 2016 16:47:16 +0100
Subject: Re: (meteorobs) Quadrantids 2016 from Spain, above the clouds
Thanks Ferrucio, Rohankumar, Salvador!
is an off-the-shelf product, comercial brand. Simply we don?t want to make
mission costs 4500?, and up to 3500? are most of the times reusable for the
Best,
Paco
Благодарности: 217
Добавлено: Пн Янв 11, 2016 17:00    Заголовок сообщения: Ответить с цитатой
Проект интересный. Сколько Квадрантид словили?
Добавлено: Пн Янв 11, 2016 18:34    Заголовок сообщения: Ответить с цитатой
Виталик пишет, что 9, т.е. стоимость одного метеора в кадре 500 евро. Very Happy
Добавлено: Вт Янв 12, 2016 09:28    Заголовок сообщения: Ответить с цитатой
Ну у нас здесь в Беларуси шарик падать в Средиземное море не будет ..))
Сниму все координаты метеоров и определю радиант в проге "RADIANT-1.43" ..
Да, проект интересный! ) Wink
